03-14-2023 05:49 PM
I switched from Bell to Public Mobile 2-weeks ago and ever since I have not been receiving SMS text messages from certain contacts/phone numbers, both Android and iPhone. I have the same Android phone that I had with Bell. I tried restarting the phone, putting the SIM card into another phone, and manually inputing the APN number. Nothing has worked.
03-14-2023 10:42 PM
@idavis1 wrote:I did reply "yes" to the porting text.
However, I found my old Bell SIM card. When I put it back into my phone I received all of the missing texts and calls.
Is there a way to re-port the number from Bell as it seems that my old SIM card is still active?
@idavis1 it is only true if your Bell sim card can still make outgoing calls and receive incoming calls , which mean it is active. Check it
Yes, you might have replied the text, but you might have replied late.
03-14-2023 10:37 PM
It sounds like the porting is not completed. Yes, your Bell account is still active.
You need to reply within a 90 minute window or porting will be cancelled.
You will need to contact a CS_Agent to have them restart the porting process.
Some members here have the number to the PM Porting department but unfortunately I don’t have it. Someone here will private message you the number.
So keep the Bell SIM in your phone and wait for the text again.
03-14-2023 09:52 PM
Checked. Non of these contacts are blocked on my phone.
03-14-2023 09:52 PM
03-14-2023 09:51 PM
To answer your 2 questions, yes to both. I can send both texts and calls when I switch phones. However, I still don't receive the majority of texts sent to me, both Android and iPhone.
After resetting the Network Setting and turning off the Chat Feature I am still not receiving most texts and calls, both Android and iPhone. Though I can send texts and make calls.
03-14-2023 07:38 PM
@idavis1 -
Perform a Reset of your device's Network Settings. This also resets Wi-Fi networks and passwords, cellular settings, VPN and APN settings, and connected Bluetooth devices that you've used before.
Find and tap Settings > System > Advanced > Reset options > Reset network settings.
Wait, you said when you put the SIM card into another phone the TEXTS still don't come in. Is that correct?
Can you send out texts to these people successfully?
Can you receive calls from these people successfully?
Both iMessage and Chat Features require a wifi connection or data to send/receive texts. Are you or any of these sender using these features?
Disable your Chat Features:
03-14-2023 06:38 PM - edited 03-14-2023 06:41 PM
Since you ported over to PM, did you reply with YES to the text with the Bell SIM in your phone?
You have 90 minutes to confirm or the porting will be in limbo and as a result, calls and text are not going through.
The Bell SIM should still continue to work if porting is not completed.
But try rebooting your phone first by powering off your phone then power back on…see if that works.
03-14-2023 06:05 PM
double check to see if you haven't accidentally blocked those contacts on your contact list.
