11-08-2022
04:58 PM
11-08-2022
05:09 PM
computergeek541
I just signed up for the Public Mobile Network and I'm not getting any texts or calls.
11-08-2022 05:17 PM
Thanks, I got it sorted out now.
11-08-2022 05:15 PM
Hi @BryceO I will send you a number and you can talk to PM porting team to re-initate the porting request
Remember to put the old sim card back
11-08-2022 05:13 PM
I had forgotten to accept the port via text with the old sim card. My bad!
11-08-2022 05:10 PM
Did you port in your number?
Can you call/SMS out?
11-08-2022 05:05 PM
Did you do a number transfer? Until the transfer is complete, incoming calls would continue to go to the old phone service. Also you need to have confirmed the number transfer via the old service in order for it to complete. If you have done this, then it might take a bit of time for the transfer to complete.
11-08-2022 05:00 PM
