Not receiving SMS messages to previous carrier and cannot 'fully activate' Public my account.
11-24-2024 03:55 PM
I am trying to move to Public from another carrier. I subscribed to Public but am now getting messages from Public that it needs to send a message to my previous phone number to fully activate my public account. BUT I am not getting SMS messages from previous carrier.
The Public info says that if I press resend code, then will get option to send to email instead of to SMS, But I do not receive this option.
So I am going round and round in a very frustrating loop. Need to somehow have Public send email codes and not SMS codes
Can someone help?
Joining Public
11-24-2024 08:27 PM
the issue started with porting my number today, i didn't get any confirmation messages from PM but my account says that it is my number.
11-24-2024 08:24 PM
hi @SMClarke
if you cannot even make calls, that is not porting but account setup. You have to submit ticket for agent to check
you can submit ticket by direct message:
11-24-2024 08:20 PM
i can't make or recieve calls but im going to use my daughter's phone to call them
11-24-2024 08:19 PM
hi @SMClarke
can you make outbound calls? it is only a porting issue (and porting team can help) if you can make outbound calls but not receiving inbound
I just sent the number to you, check your Community inbox
11-24-2024 08:18 PM
can I also get the number i've been stuck waiting on the for the past 8 hours and no response. I'm having the same issue with porting my number
11-24-2024 06:16 PM
Thank you for sending number. They did not reslve problem but were helpful and you and the lady on teh phone gave me back confidence in Public! I was getting ready to give up!
11-24-2024 05:09 PM
Also, your current carrier plan needs to active to receive the port request text. Is your present plan active?
11-24-2024 04:42 PM
Do you have the old SIM in your phone to get the text from your old carrier?
11-24-2024 03:59 PM
hi @AJ32
check with PM porting support team and confirm. I will send you the number to PM Porting support team Please check your community inbox
