12-12-2022 01:11 PM - last edited on 12-18-2022 11:03 AM by Dunkman
A week or two ago I suddenly stopped receiving 2-step verification codes from Microsoft. Everything else remains functional.
Could this be a Public Mobile issue? It seems unlikely, but I'm having a tough time getting the issue resolved.
12-12-2022 03:33 PM
HI@slugboy6000 make sure you didn't block the shortcode used by MS
and, why don't you use Microsoft Authenticator? it is safer then text
12-12-2022 03:19 PM
Thank you for all of the replies.
If it's not a Public Mobile issue then I will let Microsoft sort it out.
12-12-2022 03:07 PM
How about considering changing MS 2FA to using the authenticator app instead of SMS? You won't have to rely on SMS system regardless of carrier.
12-12-2022 01:45 PM
If you use a VPN app or service, maybe turn it off and try getting the 2FA text again from Microsoft.
12-12-2022 01:41 PM
Microsoft recently sent out noticed about updates to their Terms of Service.
You might want to check out the new Terms of Service and see if you have to do or accept anything.
12-12-2022 01:35 PM
I changed plans recently, if that matters. I don't have any blocked numbers and I still receive 2FA SMS from all other vendors. I just wanted to make sure it wasn't something at my end - thank you.
12-12-2022 01:23 PM
@slugboy6000 wrote:A week or two ago I suddenly stopped receiving 2-step verification codes from Microsoft. Everything else remains functional.
I just login Microsoft account, don't need 2FA. It could be Microsoft account acknowledge my IP address, so don't need it. Same as when I login RBC bank until I went to other place therefor the IP address has been changed, then need 2FA code or security questions answer.
12-12-2022 01:16 PM
@slugboy6000 , if things were working before, there is no reason why it should not continue to work. By chance have you complete a number change recently or maybe blocked SMS on the messaging app?
