Not getting notifications voicemail
arabeeah
I checked my phone and the notifications with apple. Nothing is wrong with mobile settings. I tried another SIM from different service providers on my phone worked no problem getting voicemails notification. It seems like from PM service. Please help
umnikke8
It most likely is a Public problem, notifications have almost never worked since I've joined Public.
HI @arabeeah   Please try to reset network settings first. If that doesn't help, then  try "reset all settings".
@hTideGnow @I do not no !
HI @arabeeah  which iOS version is that?
@Handy1   You have the link to the Apple issue you talked about?
Is it on a apple device by any chance I’ve heard of an iOS issues regarding just this
@arabeeah  did you just upgrade your iOS not long ago?  Look like it is s an issue with the latest iOS update
You might need to open ticket with Apple or check on the Apple Communities forum as well
