12-23-2017 12:42 PM - edited 01-04-2022 03:10 PM
I have a new mobile phone it's a LG V10 and my network and Wi-Fi is working great but my data isn't working at all. Can you please guys help me solve my problem? Thank you
12-16-2019 07:57 AM
@pesche wrote:I can not use data . I have 1GB left .
What kind of phone do you have? Model? New to pm? Has it worked before either here at pm or at another provider?
12-16-2019 07:43 AM
Log into your self serve account and if no amount of data is showing under data and add-ons then it has been used up.
12-16-2019 07:37 AM
12-23-2017 11:19 PM
@Paulettes I will concur with @Taekgun network settings reset and then Factory reste are teh only options for LG phones.
here is a good summary of how to get data going:
12-23-2017 11:15 PM
In addition to the suggestions already provided, please check your APN settings. Especially if this is the first time you're trying to use data on this phone.
12-23-2017 12:51 PM
There is a known issue with LG phones needing to have a network settings reset or a factory reset in order to be able to have their device work on a new network.
Its a total hassle but appears to be the only way to get your device to work. Be sure to back up your data before starting a factory reset.![]()
12-23-2017 12:45 PM
@Paulettes wrote:I have a new mobile phone it's a LG V10 and my network and Wi-Fi is working great but my data isn't working at all. Can you please guys help me solve my problem? Thank you
Did your data used to work before? Did your plan renew recently? Have you checked in your self serve to see if you have not used up all your data for this billing cycle?
