Not able to "Confirm your Identity "
Alinator
Set up a buddy on Public Mobile.
He is using iPhone with a physical sim card.
Payment went through, and he received welcome to Public Mobile email.
When Sim card arrived, put it in phone. Seems to connect.
Went into app to finish registration, no code is texted to the phone.
"Resend" code requested multiple times, still no code.
We can call and text back and forth each other on Public.
Some folks cannot call or text him.
Should note he transferred his number from Bell.
He  did not receive a confirmation text  from Bell to transfer number.
 I can still text and call his transferred number just fine?
Any help on finishing his registration to get full use of his phone number back would be appreciated.
Thank you!
Alinator
Appears that porting got stalled, and was not completed.
Tried swapping some cards, but did eventually have to have my buddy call Telus.
They were able to sort it out, and all is good now.
Thank you...
Alinator
Thank you for such a quick response.
HI @Alinator
have support agent to enter the sim number for you.  please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
Alinator
Great idea, soon as we are home we will try putting the old sim card back in to hopefully get the code.
Thank you
@Alinator
the 2FA code was still sending to your sim card with the old carrier.  Put the old sim back in and would be able to confirm identity
if that deos not work, please open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Login" and finally click "Click here to submit a ticket ↗
TheSterlinger
@Alinator  hi You will need to re-initiate the porting process. I will send you the phone number via private messages. Check your inbox, click your avatar then click messages.
However,  it seems issues with account also. He would need to submit a request to Public Mobile re account setup.
Or
