International texting not working
Edward8
My plan has international texing but when I send an international message to Kenya, it says 'failed'. But when I send to Canada or USA, it sends successfully. What's the problem?
11 REPLIES 11
@Edward8   Does everything else work, voice (in and out), data, other texts incoming?  What messaging app are you using for SMS?
hi @Edward8
did you try my way to text?  how you enter the number anyway?
Edward8
It doesn't matter if it is a company or a person. The ext is not going through. I have tried both cellphones
Edward8
I have tried his in vain
Edward8
Public mobile has international texting and I used to use it until 2 months ago when I went on vacation. On return it is not working but my plan should allow I to work
@Runningman1990   Public Mobile plans include unlimited international texting for texting from Canada to other countries not just USA.  Public Mobile doesn't work at all in any country other than Canada and the USA.  I believe the OP is texting from Canada to Kenya.
Runningman1990
Hello Edward. You can only send text message to a canadian #. If you have international texting, it extends to a USA#.  It does not work for any other country. I tried it when I was in Ireland and Italy - no go.  You could partially solve this if you get a esim, get data, and get a VOIP# with world wide texting if you need to text. I used either Nomad or Airolo for my esim for data. Then I use a Fongo VOIP phone for my texting and another canadian telephone #.
Meow
Issue could be on Kenya side not able to receive SMS.
Can you Receive SMS from Kenya? If you can just reply on SMS and see if it gets there.
Sansan
Is this the first time you have text there? Are you texting a company or a private person? See if they are able to text you first and the reply to their text.
HALIMACS
Here's what is recommend,  @Edward8
Have them text you 1st, then reply to that text.  Then add that incoming number to your contact for that person.
hi @Edward8
how you text them?
 you should be using this pattern
011 254  (City Code ) ( Local Number)
