Not able to make phone call, but text message works.
cd0207
Hi,
Starting from last week, I am not able to make any phone call, it beeps 3 times and failed.
Nor people call me, shows call failed, tried reset network setting, reboot the phone, clean sim card, no luck. But text message works.
Thanks,
David
@Ardbeg54   your friend could be impacted by the VoLTE enabling on his account.
Try to power off the phone and then power up to try again
If still unable to make calls, try to enable VoLTE on the device itself and see if calls can be made using VoLTE
If nothing works, open ticket with PM Support and they might have to refresh your account from their end to resolve the issue
Please open ticket with PM support using Chatbot:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
Ardbeg54
My friend on public mobile has this issue. We have not been able to figure it out yet you can text but when I call I get three beeps. Very frustrating
maximum_gato
@ssander
Public mobile just implemented VoLTE calling. Work with customer support to fix the calling issue it may not have set up correctly within your account. They will respond to you via your private messaging the envelope icon at the top right corner of your screen next to your avatar.
DennyCrane
Make sure your network selection is set to auto or LTE. If you're fixing your phone into 3G you're probably going to run into more and more issues with phone calls as time goes on.
ssander
Exact same issue here. It started last Thursday or Friday. Phone is an iPhone 11. Tried everything. Sometimes it works after multiple attempts to disable the cellular connection and re-enabling it. 100% a service issue. Started to reach out to a CS agent. If nothing happens by tomorrow, I'm leaving.
@cd0207
mobile data work?
do you have another phone to text your sim card?
Also, what phone do you have? wonder if you can try toggling the VoLTE and test with it on and with it off
