Voice not working in US
10-05-2024
08:19 PM
10-05-2024
10:51 PM
computergeek541
Voice, data and text were working in Canada,
After crossing into US only data and text works.
cannot make or receive any calls.
Tried turning phone off and on, as well as airplane mode off and on.
Service
10-05-2024 10:48 PM
@Neil11 wrote:You're still roaming when you're in the US, but it's included in your plan so there are no extra charges. You'll want to:
1) Turn Data Roaming ON
2) Set Network Selection to AUTOMATIC
3) Set Preferred Network to 4G/LTE (because roaming on AT&T 5G doesn't work)
The customer is having issues with voice calls. In this situation, the data roaming settting is irrelevant. In addition to that, data is actually already working, so it must already be turned on.
10-05-2024 08:54 PM
10-05-2024 08:32 PM
is your phone on this list? if yours not in the list, then it is a problem with VOLTE
10-05-2024 08:28 PM - edited 10-05-2024 08:29 PM
hi @RRP the roaming voice problem probably because your phone not on PM's VoLTE whiteliste. What phone is that?
try connect to T-Mobile and check if voice work on the 2G network
if not, you need to use other VoIp app like TextNow to make and receive calls on the app (TextNow will give you another phone number)
