02-21-2025 02:53 PM
Does a public mobile subscriber have the option of down grading from a voice text and data plan to the $19 per month voice and text only plan?
Plans
02-21-2025 04:08 PM - edited 02-21-2025 04:08 PM
@Cavendish You might be interested in a current Telus promotion, $100 for the year, unlimited Canada calling, texting and 2GB of data a month. Works out to $8.33 a month but you pay the year upfront. It reverts to 400 mins + 400 texts and no data after the year but you may find something you like here as a new subscriber then.
02-21-2025 02:57 PM
yes, you are allowed to downgrade. But you cannot downgrade to any plan you want. the option is based on your current plan and not everyone has the same
02-21-2025 02:56 PM
@Cavendish wrote:Does a public mobile subscriber have the option of down grading from a voice text and data plan to the $19 per month voice and text only plan?
Hello @Cavendish
When you open the app, when you click on change subscription, what you see there is what you can get. Sadly, for a prepaid service, you don't get the option to downgrade. Only option is to port out and port back in to keep your number.
02-21-2025 02:56 PM - edited 02-21-2025 02:57 PM
When you sign into my account and click subscription & add ons then click change subscription, the plans you see are the only ones you able to switch to.
https://myaccount.publicmobile.ca/en/account/plan/change-plan
if you find a plan you want to switch from then click change on renewal so that you are not immediately charged for new plan.
