Not able to make calls
jkrietze
I can’t make or receive calls. I’m in good standing with my account. I have reset my phone, turned the airplane on and off and I have also tried selecting the public mobile carrrier manually. Nothing works. Please help.
15 REPLIES 15
@jkrietze wrote:
No change. Nothing works.
@jkrietze - Were service working previously and this just happened all of a sudden?
Did you just activate a SIM /account with Public?
Check one or the below:
Is your phone locked? Contact your previous provider to unlock it for you. You will need your imei number, dial *#06# to get it.
Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
Check for outages in your area:
https://www.telus.com/en/on/outages
https://istheservicedowncanada.com/status/telus
https://downdetector.ca/status/telus/map/
@jkrietze
What device are you using?
How is text working if you can't connect to the carrier?  Are you using Imessage or another app?
Are you also connected to your home wifi network?
@jkrietze but when it is on 3G, does the phone connects to )M network at all?
either way, open a ticket first , although support might not reply till the morming.
jkrietze
jkrietze
I’m active.
jkrietze
Doesn’t matter if I’m on wifi or not. No Cal’s coming or going.
Is that texting on an iphone while connected to wifi? How about can you browse the internet on cell data and not wifi?
@jkrietze
so, it doesn't look like a device issue, it could be account or local network issue
Try changing the Preferred network type to 3G as advised above. Important part is to check if it connects after changing to 3G network
If nothing works I guess it is time to open ticket with Support
1. Please open ticket via Chatbot (requires access to My Account) using direct link: https://publicmobile.ca/chatbot.
Start by typing "Contact agent ", then click "Contact Us", then click "Other", click "Click here to submit a ticket ↗""
Next, enter your Community login, then enter your question.  Finally use My Account login or 4 digits PIN to validate.
jkrietze
Texting works fine. Just get two beeps not long after attempting a call
jkrietze
I tried taking out my sim and trying in another phone and it didn’t work. Reinserted into my phone and doesn’t work still
@jkrietze text and mobile data work?
what kind of phone do you have? brand and model?
try changing the Preferred network type or network mode to 3G only (or WCDMA only) and see if it connects to PM Network and if voice works
jkrietze
Phone not showing anything to say not connecting.
no I don’t have another phone to try the SIM card elsewhere. I’ll remove it and reinsert.
@jkrietze cam you login My Account  once more using Incognito mode ro confirm 8f account showing Active?
Also, does you phone showing not able to connect to PM network at all?  Any error like sim not provisioned or No Sim or No network?
Do you have another phone around to test the sim card??
jkrietze
It won’t let me make any calls at all. I get 3 beeps and it drops the call. No matter who I call, even 611.
hairbag1
@jkrietze
you still have an Active PM account ? Dial 611 from that cell phone to hear status of your account.
Let us know.
