03-09-2024 10:23 AM
03-09-2024 10:42 AM
@KunalKumar first try the sim in another phone if possible (if you have physical sim and have another phone around)
I also, test the phone with 3G mode as said above and test in different area, in case local Network problem
last, open ticket as advised above
BTW, what city you are at??
03-09-2024 10:40 AM
Yes start is active green and subscribed
03-09-2024 10:40 AM
Yes I tried by resetting the network. Activation of plane mode and even restart 2 times. But still not able to make and receive call 😔
03-09-2024 10:38 AM
Portal is showing as green subscribed status .
03-09-2024 10:27 AM
@KunalKumar does data work??
did you check if your account status is active? To avoid browser cache confusing, please login My account using Incognito mode to confirm account status
If it shows On Hold (Suspended) , then it is a payment issue. Click "Pay Now and Resume Services" to make a manual payment
If it shows active,
if nothing helps, please open ticket with PM support:
03-09-2024 10:26 AM
@KunalKumar - Did you try to reset your network settings? Try rebooting your phone. See if it works, if not, ask CS_Agent about the issue with the link below:
⬇️ Click the link for an Agent * ⬇️
If the link above doesn’t work go here to create a ticket to CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
* - CS_Agent will typically get back to you within 48 hours. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for an agent because they may notify you asking for some information via Private Message, in your mailbox by clicking this link here: Messages
03-09-2024 10:26 AM
Can you log in to your account and confirm status is Active?
