a week ago
I successfully transferred my number on Thur but I can only make calls. I submitted a ticket and hope someone can help me with a solution.
a week ago
a week ago
I have the same issue! So far customer support has not been able to fix it!
a week ago
Hi! As soon as I switched from my old company to PM the only thing I can do is make calls. I can't receive or send texts and I can't receive calls. My data is working, yes.
a week ago - last edited a week ago
Hi @Charla, were you able to receive calls before? What about texts, can you send and receive? Do you have data working?
Your best bet would be to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
