06-24-2026 08:19 PM
To day I have no service. Not able to make or receive calls or send or receive messages. No network
06-25-2026 09:36 AM
Thank you for the escalation! The customer is in contact with an agent.
06-25-2026 09:18 AM
I tried all of the above. Nothing works. I asked agent to reset my account I don’t know if that has been done
06-24-2026 09:20 PM
The PM agent has to reset my account
06-24-2026 08:59 PM
Did not fix the problem
06-24-2026 08:28 PM
@Jo-JoR wrote:To day I have no service. Not able to make or receive calls or send or receive messages. No network
Hello @Jo-JoR
First, dial 611 from your phone and confirm if your account is active or not. If you can't even connect to the network, try turning your phone into Airplane mode and then turn off your phone for 5-10 minutes. Then turn your phone back on, turn off Airplane mode. This will reconnect you to the Public Mobile system. Then you can dial 611 and confirm active account or not and go from there.
06-24-2026 08:22 PM
hi @Jo-JoR
check any outage in your area
https://www.telus.com/en/on/outages
And login My Account to confirm if your account is active or not. If it is suspended, you will need to make a payment to resume
and if it is active, try Reboot your phone and click reset network settings and test
if same, ask PM agent to refresh your account.
you can submit ticket by direct message:
