6 hours ago
Hi. When not on wifi on my iPhone , I can’t seem to get anywhere using data. I used to be able to look up anything I wanted to, but nothing now. I’ve checked all the settings & they all seem turned on & fine. Have turned the phone off & on. Also have plenty of data. Any ideas? Thanks
6 hours ago
Thank you softech for the reply. I’ve been with Public Mobile for years with no problem. I’ve taken your advice & sent a message to CS Agent. Thanks, Sue
6 hours ago
hi @SAbbott1
if you just joined Public Mobile, make sure you removed the old provider's Sim card, or disable the old provider eSIM. Then check and confirm PM sim is enabled and set as Primary. Also, make sure the Carrier Profile is updated (Settings > General > About) Last, proceed with a Reset network settings after a device reboot
If issue persists, you will have to contact PM CS agent to for a account reprovision. Private message CS Agent at:
