2 weeks ago
I can’t get any kind of service after waiting 6 hours from signing on to public mobile
2 weeks ago
Thanks for your help
all is good now
2 weeks ago
@softech wrote:@Camaro69 if you are using a physical sim card now, go to the Sim Manager (or on iPhone Settings > cellular ) and delete the PM eSIM.
Then, Reset Network Settings after a device reboot phone once and it should work
Sounds to me like Camaro69 now has esim, and struggling to activate it.
2 weeks ago - last edited 2 weeks ago
2 weeks ago
The support team changed my SIM card by using eSIM
2 weeks ago
@Camaro69 wrote:How do I disable the existing SIM card
I was given assistance to change it over to PM WITH THE HELP FROM the support team
Are you using hard sim ? If so, remove the old network sim and install the new Public Mobile sim.
2 weeks ago
Yes no luck
2 weeks ago
2 weeks ago
@Camaro69 make sure your old provider sim card is removed, or if disable it if the old one is an eSIM
then check and make sure PM sim is enabled (toggle on Turn on this line on and set the label with Primary if you have an iPhone)
Next, Reset network settings after a device reboot
if you still cannot get it to connect to PM, you will need to engage support agent and ask them to reprovision the sim. Private message CS Agent at:
2 weeks ago
did you reboot your cellphone ? If so, now try a network re-set...see if that helps.
