No Limits ?
RCO1
Hey all I haven't posted in a while but I have an unlimited plan and that I just feel so much more comfortable when I have that little bit of data I'm just in case
Basically I'm just making a suggestion and ask him for your support like that they would start doing it again because I would easily sign up there's a data that's got about 20 gigs more at the 5G but if it had that unlimited component even on the throttle back I would be just so much more comfortable
Hope to hear some of your feedback and and encouragement that PM might implemented in the not too distant future
RCO1
Yeah I get it
but even if I go up to a larger data bucket I'm still in the same situation there at the at the end of the you know the 30 days and then to have that little bit of access just for email I think it would be a kind of a well it would be good for the customers of course but I think it would be a good for as an attraction for for people as well
I might add that one it was one of the main reasons that I went with public was the unlimited and I can't imagine that there aren't other people that are at winter are be attracted by that
Dunkman
@RCO1
Public mobile is offering plans that new customers want.  Unlimited throttled Canada data plans do not seem to be too popular with new customers these days.  Customers prefer larger data buckets (with regular speeds) and US and Mexico and US roaming plans.
The unlimited throttled data seem unusable for many customers.
RCO1
For what it's worth
even the throttle down speeds at with the unlimited it's a comfort just to be able to get to do a bit of email if you know if it gets close I just I don't actually go over all that off and but to switch to a plan that is capped I'm just having a difficult time I'm hoping that maybe there was people that might agree a little bit or be you know where the powers that be it to PM . We should consider.
all the best for now
Would appreciate some other feedback from anyone else too
slusagm
as you know PM only give unlimited plan for Canada only plan
but PM has put in big focus on roaming plan, so, the unlimited Canada plan won't come too often, even it is coming back
but honest, plans are now 50GB, 100GB or so, there is really no need of that unlimited component
