‘High Speed’ data limit?
Alicat27
I am in my first month of the $25 25gb plan (with the extra 10gb /month promo also). I have used a total of 8.3 Gb so far but I just got a message that I’ve used up 75% of my ‘high speed data’. What’s that about? If I have a total of 35GB to use, why am I being told I’m nearly at my limit for high speed? When I google it the answer says that if you pay for 25GB of data on PM then you get 25GB of high speed data.
2 REPLIES 2
Alicat27
Thanks for the reply. I’m surprised that it uses the bonus data first, but that’s really helpful to know.
hi @Alicat27
the message is confusing.   the 75% used message is actually about your 10GB bonus data.  After you used up 90% ,  100% of the 10GB, you will get those text as well.  But no worry, the system will start using your regular 25GB data.  So, just ignore those texts
