04-21-2026
06:26 PM
04-21-2026
06:44 PM
computergeek541
04-21-2026 08:30 PM
We appreciate your escalation. An agent is already assisting the customer and will ensure they receive the support they need.
04-21-2026 06:33 PM
@Costab99 check if the eSIM already installed by the app. Go to your Sim Manager or Settings -> Cellular to check. Make sure it is enabled, and set as Primary. Reboot phone and Reset network settings and text
but if the esim really not there, ask PM to help
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
04-21-2026 06:32 PM
You'll need to reach out to customer service this way.
If you’re unable to log in to your account, please use this direct link to reach out to a CS Agent.
