02-21-2022 12:47 PM
because, the phone says - Cellular Update Failed, Your iPhone cannot make and receive calls or access cellular data until it has been updated. Apple tried to fix the problem but it was unsuccessful. Apple cannot fix the problem, it is the Carrier ,Public Mobile.
02-23-2022 04:59 PM
Thank you guys for your help. My problem was solved by a reformatted SIM card, than I went to Apple and the support guy checked for problems on my cell phone, found out the antenna was not receiving a signal from Public Mobile so he rebooted my phone and now its working as before, great.
02-21-2022 04:17 PM
02-21-2022 03:50 PM
02-21-2022 03:44 PM - edited 02-21-2022 03:47 PM
You are correct after I checked the 5S which I have accessed to long time ago. APN has only one field which is the mobile server address. Updated my post to remove the reference.
02-21-2022 03:08 PM
Yes, I forgot the difference with Telus vs PM. BUT when I switched over to PM there was no "download" involved. I put the SIM in and adjusted the APN setting and that was it...and the options of APN adjustments on an older iPhone are very minimal.
02-21-2022 02:41 PM
@CountyDownIeUk wrote:
@popping wrote:One of my family member is using a iPhone 5S with PM call/text/data plan. iOS 12.5.5 is the latest version for 5S because Apple had stop supporting 5S.
You need the PM specific file to be added on your phone before iPhone 5S works with a new provider if it was use with other provider.
What is the iOS version on your iPhone 5S?
Can you update your 5S while connected to WiFi?
When all failed, connect to a PC running iTune to update your 5S and get your PM specific config file.
Good luck.
In bold red......that is confusing.....what do you mean?
OP Says phi was was working.
My MIL had a 5S on Telus with no issues.
Best suggestions have been to do:
1. Reset or review your carrier settings
2. A full reset on phone, but back it up first on the iCloud or on a computer with iTunes
3. You can do a reset on a computer using iTunes as well
And just to add, if you do a full reset on the phone using a computer using iTunes, the last screen will say the phone is unlocked....if it is. If locked.....no message either way.
You asked "In bold red......that is confusing.....what do you mean?"
After changing provider, user needs to download a provider specific config file before an iPhone can be used with the new provider. I did not mention about restarting iPhone to configure the iPhone with the info in the provider specific config file. IIRC, after update, iPhone always restarting itself.
Working with Telus does not mean it will work with PM. e.g. PM uses 3G for voice calls only. Telus does not have this restriction.
02-21-2022 02:21 PM
Good luck.
02-21-2022 01:43 PM - edited 02-21-2022 03:45 PM
Good luck.
02-21-2022 01:43 PM - edited 02-21-2022 01:45 PM
@Mon79 : No friends or relatives you can try with? We're just trying to identify where the problem is. Your SIM working in another phone would tell you the service works. Another SIM in your phone not working would tell you the phone is the problem.
If your SIM doesn't work elsewhere then it's the service (mostly). If another SIM works in your phone then again it's a problem with the service (mostly).
Then we can proceed from there. The failure to update (from your OP) sounds problematic though.
Edit: just on a whim, check devicecheck.ca to make sure.
02-21-2022 01:42 PM
I'v had the service with PM for 2 years no problems.
02-21-2022 01:40 PM
The phone is definitely un-locked been using it for years no problems just 2 days ago turned the phone on in the morning and there was no service.
02-21-2022 01:36 PM
I will try all that, thank you.
02-21-2022 01:34 PM
They did not do that, but I will go to a kiosque in Laval and check with them to put in a SIM card. Thank you, its a good idea. Obviously its only on my cell phone because nobody I heard of has this problem.
02-21-2022 01:22 PM
@Mon79 Yes, was the phone ever worked on PM or you just switched to this phone? The PM sim was working before?
02-21-2022 01:18 PM
02-21-2022 01:15 PM
I did all that with Apple service and he gave up after an hour or so and says he can't help me further
02-21-2022 01:06 PM
@Mon79 wrote:I did not try that put in a new SIM card, how do I do that?
hi @Mon79 Do you have another SIM that you know it works, put it in the iPhone and see if it works.
or if you have a second phone, put your PM SIM into it and check
Or you said you tried Apple Support, did they put another SIM into the phone and make sure the phone actually works?
02-21-2022 01:05 PM
Not new. A different working active SIM from another phone. Just to see if it might work on another service. That would verify if it's the phone or the Public Mobile service. Also try your SIM in that other phone.
02-21-2022 01:03 PM
02-21-2022 12:56 PM
The device is now past it's support limit from Apple.
Can you successfully run any other SIM in it?
02-21-2022 12:55 PM
@Mon79 did you try to make the Carrier update via iTune instead of Wifi?
Are you on the latest iOS stable version ? If not, make the update first
and if still fails, you might need to try Factory reset (but make sure you have proper backup
