02-23-2022 03:24 PM
02-23-2022 04:51 PM - edited 02-23-2022 04:53 PM
iMessage moves over wifi or data. And only to another Apple user. iMessage is in a blue bubble.
Go to settings, messages, turn on iMessage, send as sms, mms messaging, group messaging
Now try to send a text to an android user....should be green bubble.
02-23-2022 04:39 PM
I've done that, turned phone off and on, nothing seems to work
02-23-2022 03:43 PM - edited 02-23-2022 03:43 PM
When you send an iMessage, there should be an option 'hold down' the message just sent and "Send as a text message"
Also, what happens when you turn OFF data and wifi... does your messaging services revert to SMS?
02-23-2022 03:40 PM
@sequoia2002 wrote:I can only send and receive texts from iMessages,
Please go into the settings and check to ensure that the SMS feature is turned on.
