02-23-2022 01:35 PM
My landline number was accepted for transfer and instead there was a new number assigned. What happened?
How do I get my old landline number.
Other
02-23-2022 02:24 PM
@Anonymous wrote:@softech : Well that seems open to abuse. When I transferred the number out of the Telus SmartHub account I had, I was asked to provide the IMEI of the device. So maybe there's no authorization per se...but you better have the right information.
I have a ZTE box.....if I was to port out I would put SIM in a phone then do the request. The SiM change immediately reports the new devices IMEI to the carrier.
02-23-2022 02:20 PM
@Anonymous wrote:With non-textable transfers, wouldn't one need to authorize the transfer with the originating provider somehow?
Yes and depends on the voip provider. It falls back on how well you identify your ownership of the voip Account. In the case of voip.ms they will tell you exactly what information to use and as well the same shows on your online account.
Wouldn't one call them to give them the heads up saying that they're going to get a port request and that you officially authorize it?
As mentioned above. And believe it or not voip.ms does not accept calls...only email and recently they added a chat option. Your port authorization is as good as done if you provide your exact name, address, phone number and account number.
02-23-2022 02:12 PM
02-23-2022 02:08 PM
@Anonymous
I think landline or VoIP, It really depends on the company. I think I heard ppl mentioned there is nothing they need to do. I don't think there is a set rule like CRTC set for mobile carriers
02-23-2022 02:03 PM
With non-textable transfers, wouldn't one need to authorize the transfer with the originating provider somehow? Wouldn't one call them to give them the heads up saying that they're going to get a port request and that you officially authorize it?
02-23-2022 01:52 PM - edited 02-23-2022 01:53 PM
@maxdifeather wrote:Landline transfer accepted a month ago, outgoing calls only then was assigned new number without approval or explanation.
@maxdifeather A month ago? I think there has been issue with the VoIP side
You have to login to My Account, click Change Number and then re-request the porting again.
After you request, it should be done within a week. I would wait a full week and then call the PM Porting team and ask for status. They might said your VoIP provider turned down or need more info.. See what the porting team said after the week
I will private message you the phone number. Check the Community inbox on the top right, envelope icon
02-23-2022 01:51 PM
Did you port during the activation process?
Or activate with a number chosen fro PM and after requested a port?
My voip.ms took 5 days...so expect the full week to complete. And expect split services.
Contact a CSA and they will let you know the current status of the process.
02-23-2022 01:46 PM
02-23-2022 01:43 PM
The line is voip on cable.
02-23-2022 01:40 PM
Porting of land line will take few days. If you opened account just now, most likely temporary account has been assigned.
Confirm you have all services (SMS/call/Internet) in order and wait for actual land line porting to complete.
02-23-2022 01:39 PM
Is your landline still working? Is this an actual copper landline or cable or cell type landline?
Did you authorize the transfer somehow with the landline provider?
