01-09-2026 03:44 PM
Some challenges accessing my voicemail easily.
I can access my voicemail if I type in my 10 digit number.
I can’t access my VM via the Voicemail button on my iPhone, or by pressing and holding ‘1’
In my eSIM ‘My Number’ is blank. I’m guessing that’s the issue.
No number is visible in the Apple Phone App under ‘My Number’
- Live Voicemail has been disabled.
- I transferred my number before Christmas. It’s been weeks, so it’s not pending transfer.
Any help to make it easier to access VM would be greatly appreciated.
01-09-2026 05:05 PM
This worked!
I turned ‘Off’ the Cellular eSIM.
Turned it back on. When it reloaded, my number appeared automatically from Public Mobile.
Thanks!
01-09-2026 04:08 PM - edited 01-09-2026 04:11 PM
make sure you disable Live Voicemail as it could have conflict with it
Then click Reset Network Settings
if that does not work, open the dialer app, setup using the voicemail button there
choose one of the number from here:
01-09-2026 04:06 PM
Try resetting the Network settings on your iPhone and see if that helps.
01-09-2026 03:57 PM
@KEYInAB , please try the key sequences in this link to add a voicemail number. For Public Mobile voicemail, the 10 digit number is generally your area code plus 580-4001.
https://www.rogers.com/support/mobility/program-voicemail-retrieval-number-on-apple-iphones
