01-09-2026
04:28 PM
01-09-2026
10:37 PM
computergeek541
Hello,
Trying to order a Qin f25 pro and not sure if it works on Public. The listed bands are:
Frequency band 2G GSM(2/3/5/8) 3G WCDMA(BAND1/2/5/8) 4G FDD(BAND1/B3/B5/B7/B8/20/28a/28b) 4G TDD(B34/B38/B39/B40/B41)
Network type: GSM/WCDMA/TDD-LTE/FDD-LTE
Will this phone work with Public?
01-09-2026 05:00 PM
I would stay away from unknown brans no mater how deal is attractive.
Best way to check is to stick PM SIM into phone and see if it works or not.
And most likely VoLTE will not be approved by PM so you will have limited functionality outside of Canada even IF your phone is 'certified' VoLTE.
01-09-2026 04:35 PM - edited 01-09-2026 04:42 PM
the phone might work now and use 3G network for voice
But the phone is not on Pm's VoLTE whitelist and you will have trouble with voice calls once Public Mobile decommission 3G network in your area
01-09-2026 04:31 PM - edited 01-09-2026 04:38 PM
It may work but without being recognised in Public Mobile for VoLTE.. you’ll likely run into talk issues with that one. Heres some reading on VoLTE and a device checker at bottom of page.
