10-11-2019 10:53 PM - edited 01-05-2022 07:32 AM
Ever once and awhile my iPhone says no service, phones updated, tried restarting it. Taking the SIM card out for a minute and nothing helped. Put the sim in my android phone and works fine.
Any ideas as what it could be?
10-22-2019 10:59 AM
@Bradp75 wrote:Now the phones randomly shutting down. Not under warranty either 😔.
If you've updated to ios 13 you may have one of its bugs; https://www.forbes.com/sites/gordonkelly/2019/09/21/apple-ios-13-release-should-you-upgrade-iphone-1...
10-12-2019 09:17 AM - edited 10-12-2019 09:24 AM
@Bradp75 wrote:Yes it usually gets good reception, on my android phone it's got 3 bars. This is the third time it's done this in 4 - 5 months, just randomly happens. Must be the phone I think.
This does sound like a phone. If you have a different working SIM card, try and see if the problem is repeated. Apple store has good service. Maybe take it to a store and see if they can help.
10-12-2019 04:56 AM
@Bradp75If your phone is randomly shutting down chances are it is the battery that is at fault.
10-12-2019 02:32 AM
10-12-2019 12:48 AM
10-11-2019 11:53 PM
@Bradp75 wrote:Ever once and awhile my iPhone says no service, phones updated, tried restarting it. Taking the SIM card out for a minute and nothing helped. Put the sim in my android phone and works fine.
That could be faulty antenna. Are you in a strong signal area?
10-11-2019 11:31 PM
@Bradp75Check to see if your SIM card fit snuggly in the SIM tray. I would put a thin piece of tape to make sure it holds.
10-11-2019 10:57 PM - edited 10-11-2019 11:02 PM
If you can...try the sim in the other phone for a day or two to see if it's a sim issue or a phone issue.
