No service, no data!
chris61999
I put in a ticket earlier about not having the 5g service I had subscribed to. Now about 6 hours later I have been demoted from 4 to 3g service, and I have no data as well. I can't send photos or anything. All I can do is text or call. I can't even access the internet on my phone! Something is wrong, and there is no one to contact.
CSA_PM
Customer Support Agent
Thank you for the escalation! The customer is in contact with an agent.
Chalupa_Batman
Hello @chris61999
Try something that has worked for some folks.
Turn on Airplane mode for 10 minutes. Then, after 10 minutes, turn off the phone for 5 minutes. Then turn it back on and after it's restarted, turn off airplane mode. This reconnects you to the Public Mobile network and may help reconnect your data.
@chris61999
First, what phone do you have?
People are using  4G or LTE for as good the connection as 5G, so, your issue is honestly not because you are not using 5G
Please proceed with a Reset Network Settings after a device reboot and try again
If same, then you might need to update your APN if you are using Android, or update the Carrier Profile if you are using iPhone
And  I have also escalated your ticket on your behalf.  PM support will reach out to your via Community inbox.  Please monitor here for their reply:
(Since it is a bit late tonight, they might not reply you until tomorrow morning)
