07-02-2026 11:29 PM
I signed up on the website and paid for the activation then downloaded the app. I am transferring from Fido. Got error message on the app saying 'Subscription not activated' after following all the steps.
Registered email is [email protected] on $25 plan.
07-03-2026 07:55 AM
Thank you for the escalation! The customer is in contact with an agent.
07-03-2026 12:26 AM
@dannyhoyvr wrote:Its been activated. I am now getting error trying to transfer from Fido.
I'll send you a link to your Community inbox...I sent you a message with a number you can call for port assistance.
It might be wiser to call in the morning though
07-03-2026 12:04 AM
07-02-2026 11:50 PM
@dannyhoyvr wrote:Ok so activation on a temp number with Public has been successfully but when I filled in account details to transfer my old number from Fido, its not successful.
In order to transfer the number to Public Mobile, your Fido account must be active and in good standing. Is the account still active ?
07-02-2026 11:47 PM
07-02-2026 11:39 PM
@dannyhoyvr try Reboot phone and login PM app and the app could complete the activation then
If you still got an error and if you are activating eSIM, check if the eSIM already installed. Check the SIM Manager or Settings > Cellular screen and see if the Public Mobile sim is there. Enable it and set it with label Primary , then Reset Network Settings and try again
But I have also escalated your ticket on your behalf in case the above does not work. PM support will reach out to your via Community inbox. Please monitor here for their reply:
(Since it is a bit late tonight, they might not reply you until tomorrow morning)
07-02-2026 11:32 PM
to successfully activate your new Public Mobile account, you must download the mobile app to your cell to complete the process. You can either take a new number to start or initiate transfer of your Fido number to Public Mobile.
