04-20-2024 01:33 PM
I can’t login, make calls, receive calls, text or anything. The Chat gets me nowhere. I’m in a basic loupe. My sim came I followed the instructions, transferred my number from Telus. Set up an account, then a day later got a text message from 611 saying I have successfully created a new PIN. Keep this number safe as it'll be used to authenticate your identity.
i never got a pin. I call 611 and it says my account is suspended. But yet they’ve taken my money out on my credit card. I’m stuck in limbo. To be honest I’m surprised I’m able to write in this community.
I need my number back. I can’t have a service that’s been unstable like this. It’s been three days and I still have no functioning phone service. My wife is having similar issues only she’s actually got service but no data. We activated separately. This is crazy. I’m left sitting here with no phone. I run a business from this number. I’m not happy with this company. I wish I could get some help.
04-23-2024 04:28 PM - edited 04-23-2024 04:29 PM
04-23-2024 04:10 PM - edited 04-23-2024 04:31 PM
They've sent. attached is a screenshot. I realize this isn't the normal way of support, it seems as though their system has malfunctioned in more ways than one- a black swan event perhaps.
04-23-2024 03:58 PM
@Renderdc Can you check your Sent folder (under the Inbox) to make sure your private messages actually sent? Assuming they were sent, do you see the envelope icon on your community page? That's where replies will come but if you don't see an envelope icon you need to tap your avatar and check Messages in the drop down. This is just to make sure they didn't reply and it was missed. It's unusual for them to take this long but seemingly it happens and that would indeed be extremely frustrating.
04-23-2024 03:31 PM
Thank you but nothing has been successful.
04-23-2024 03:30 PM
The agents are failing to resolve issues. Nothing about my service works. it's not a dual sim. this has been since Friday of me going on and sending support requests for 5 days now. it's consumed my whole week. I have tried everything.
04-23-2024 03:25 PM
This is garbage. I have been without a phone since last Friday and can't even log into my account. Support won't answer my tickets. This is so frustrating I am losing my mind. So far they've taken my payment and have not acknowledged my existence. I am so pissed right now.
04-20-2024 09:38 PM
I did call this number. The Lady was from TELUS and was extremely helpful to my Wife but my problem was outside of her expertise unfortunately, she is a porting expert only. My number didn't port properly and needs to be looked at by a PM agent. Apparently i don't exist. something went seriously wrong in porting process and I am still in limbo. Thank you so much for finding the number!
04-20-2024 07:26 PM
Thank you I tried all of the above and still nothing.
04-20-2024 07:23 PM
That link works.
04-20-2024 06:38 PM
@Renderdc Usually an agent will reply quite quickly to a private message but with the current SMS issues they are having to fix it may take longer. The phone number is not for general support, it's for specific porting issues only (it's usually not posted in the community for that reason). Hopefully an agent will get back to you soon and get everything sorted out.
04-20-2024 06:07 PM
None of that works, but thank you for offering me an option. I cannot get in via incognito, I’ve tried clearing my cache, phoning the phone number only to find out you need the account number, which I cannot sign into. It’s like I’ve been struck out and they’re holding my number now. This has cost me $120 already in activation fees
04-20-2024 04:12 PM
Thank you for your efforts. The link doesn't work for me on my laptop and on my phone. I am using both my computer and my phone. I am at the point where I will be making the efforts to terminate this PM. It's more hassle than it's worth.
04-20-2024 04:01 PM
I was able to sign into the community and was able to send a private message to a CS_agent. (Which I wasn’t able to do before. Not sure what’s different about the link. Thank you for sending over!
04-20-2024 02:56 PM - edited 04-20-2024 02:58 PM
@Renderdc If you click on this link, do you get the same thing? Are you using the app or the website? Maybe close whatever you are using and try again, in incognito mode if possible. You do NOT need to be logged in to your account, you need to be logged in to this community, which you must be in order to post here
04-20-2024 02:53 PM
I can’t submit a ticket or login I get a screen like the one
attached
04-20-2024 02:25 PM
Use the Private Message method to reach them, be sure to indicate that you "Cannot login"
Send a private message to Customer Support Agent by clicking here. You’ll need to be logged into your Community account for the link to work.
04-20-2024 02:23 PM - edited 04-20-2024 02:24 PM
To be certain, @Renderdc , you stated you can't "get" texts, calls, data.
Can you SEND texts or make outgoing calls with your Public Mobile service?
Make certain (if you may have a dual-SIM device), that the device is 'pointing' to the correct SIM in your SIM manager settings.
Otherwise, since you've tried all the typical troubleshooting items, reaching out to a Customer Support Agent is likely the best recourse as @Phil_Adelphus & @Chalupa_Batman provided each an option to do that.
04-20-2024 02:21 PM
The problem with submitting a ticket is I get an error when trying to sign in. A1 blank screen. Phone doesn’t work logging in to submit a ticket doesn’t work.
thank you for your help
04-20-2024 01:56 PM - edited 04-20-2024 01:58 PM
Hello @Renderdc
Have you tried your SIM card in a different phone? Try that if you can. Turn off other phone, insert SIM card and reboot. If it works, then your SIM card is now properly provisioned. Turn off your other phone and insert it back and reboot. You should be good to go.
Porting can sometimes be an issue. Please submit a ticket to a CS Agent for help. Just know that it may take 72 hours to get back to you as they are dealing with a lot of issues with services
To Submit a ticket, please click the following link to access the Public Mobile Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type: Customer Service Agent
IMPORTANT INFORMATION: I am not a Public Mobile employee. I am a customer just like you. Please do not send me a private message with your personal information.
04-20-2024 01:48 PM
@Renderdc Contact customer service. Submit a ticket via the chat/message icon bottom right of this page. If that doesn't work then send a private message to support using this link
An agent will reply at the envelope icon top right of this page or tap your avatar for Messages if no envelope.
04-20-2024 01:47 PM
alternative is to message Customer Support using this link. Watch the little envelop icon on top right side of page will be highlighted when they respond. Give them as much acct info as you can ..ie: acct #, phone #, name on acct, PM pin #..etc.
04-20-2024
01:41 PM
04-20-2024
08:16 PM
computergeek541
I wish someone would help me.
I’ve done everything possible to get my Telus account switched to PM but so far it’s been a terrible experience. Not being able to login, no pin, no service, nothing. Not sure how a company can run like this. I it’s been three days since I got my account setup. Only yesterday did I get a text message saying You have successfully created a new PIN. Keep this number safe as it'll be used to authenticate your identity.
I’ve paid and have seen it come out of my account. I’ve restarted my phone, toggled airplane mode, tried to login with several failed attempts. My bars are on and it says 5g and public mobile is the service provider bu t I can’t get texts or calls or data. Wtf. 🤬
can’t do this much longer without having to change my number and text my contacts from a different service provider.
