No service for three days now....
bammirato
My iPhone has been “searching” for the network for days.  I have turned data on/off, restarted the phone, taken out the sim...nothing has worked...this is so frustrating...anyone have any suggestions?  Thanks
14 REPLIES 14
 @bammirato
Your recent post disappeared. You probably did some quick multiple editing and so it goes away.
Try again.
@bammirato wrote:
@geopublic wrote:
@bammiratoDo you have another phone that you can use  to test your PM sim with? If yes, and you card works then there is an issue with your phone. Maybe try doing a network reset to  see if it connects to PM.
Thanks for the suggestion...I did try the PM SIM on another phone and it worked.  I put it back in my phone and tried disabling LTE also but I was told to set to 3G but it doesn’t come up as an option in network settings?
Try this:
https://drfone.wondershare.com/reset-iphone/reset-network-settings-iphone.html
bammirato
geopublic
bammirato
@hairbag1 wrote:
You'll have to send a message to mods...Click this to message them.
They might take up to 48 hours before responding to you so please be patient. Good luck.
Thanks very much...appreciate the help!!
bammirato
Yes thank you
bammirato
Existing customer for a year and a half...
bammirato
Thank you...tried this but no luck
hycm53
@bammirato wrote:
Is shows ACTIVE
Is your iPhone unlocked?
@bammirato  - Was your phone working previously, or was this a new activation?
@bammirato wrote:
Is shows ACTIVE
You too can try the Lost / Stolen remedy. Log into My Account / Plan and Add-ons/ Lost-Stolen. SUSPEND service then log out. After 5 minutes log back in and RESUME service. See if that does the trick. Good luck and let us know when it's fixed.
bammirato
Is shows ACTIVE
Lieux
What can you see in your self-serve account ACTIVE or SUSPENDED?
