04-26-2019 05:45 PM - edited 01-05-2022 04:37 AM
04-26-2019 05:48 PM
@linar , are you unable to receive the reset email in a timely manner or is the process of changing the password not working for you. The password reset is rather finicky. I suggest reaching out to the moderator team for assistance to reset the password. The moderator team can be reached via private message using this link. Please include a detailed description of the issue and the required resolution. This will speed up problem resolution significantly. Refer to the following knowledge base link for additional information on contacting the moderator team.
04-26-2019 05:47 PM
Solved!
