No operation
11-23-2023 08:21 PM
Any calls to me it goes directly to voicemail. Also I don’t receive sms messages
Service
11-23-2023 08:44 PM
If you actived your SIM on May 26, 2023 then it is a backend issue then you need to contact a CS_Agent to investigate and fix at:
Staff are available from 9:00am to 10:00pm EST.
I had the same issue about 9 months ago.
11-23-2023 08:24 PM
did you just join PM and requested porting your number into PM ?
If you are porting your number, did you reply a text to your old provider and reply YES within 90 mins? If you miss that, the porting was not completed and hence you are not receiving incoming calls. There is a number you can call to talk to live support and re-trigger the process. I will message you the number, please check your Community inbox, envelope icon on top right
if you are not new to PM, incoming calls and text were working fine before and just not working now, try to :
- reboot your phone once.
- reseat your sim card (Power down the phone, take sim card out for a minute, then put it back and power up)
- change your Preferred Network Type or Network Mode on your phone to 3G Only (or WCDMA)
- Try to click Reset all networks and see if it helps (please note it will also delete your saved Wifi connections, but you can easily add them back later)
- if you have another phone, put your sim card in that other phone and test
- use your phone in another area, it could be a local network issue
11-23-2023 08:24 PM
Did you just port over to Public Mobile from another carrier?
![](/skins/images/02B49C0B2FC614613D221373CF8AAEF5/responsive_peak/images/icon_anonymous_message.png)
