No network since about noon
Ang3la
I have lost my entire phone service since about noon today. I was on my way out the door. I didn't get a new phone or new sim or anything. Just completely lost the mobile network.
8 REPLIES 8
CSA_PM
Customer Support Agent
Thank you for the escalation!
The customer is in contact with an agent.
Ang3la
I bought a new sim and that is not the problem. I have a bad feeling a software updated f'd up my phone.
@Chalupa_Batman wrote:
Hey @Ang3la
Have you tried to reboot your phone? Have you tried to go into your settings and reset the Network Settings and reboot? Try your SIM card in a different phone. And as silly as this sounds, have you checked your account online or via 611 to confirm your invoice is up to date?
I know the customer has said the next plan renewal isn't until a later date, but even if the customer failed to pay to have a plan renewed successfully, that wouldn't cause the phone to disconnect from the wireless network.
Call 1855-4PUBLIC from another phone and confirm if your account is active
also, you need PM to check and refresh the account on the system,  Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA  code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.)    When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox,  between 9AM-10PM EST (Mon-Sun), check here:
Ang3la
I have, my bill wasn't due until later in the month. I've rebooted my phone two dozen times, reset my network half a dozen.
Ang3la
I'm in Ottawa.
ORNGNBLK
@Ang3la  Wondering if you are in an affected area for outage? Check the Telus outage map and cross reference your location as there seems to be quite a few areas near Vancouver and hit spots Calgary to Edmonton and North.
Www.telus.com/outages
Chalupa_Batman
Hey @Ang3la
