10-07-2025
06:27 AM
10-08-2025
01:01 AM
computergeek541
I switched from Fido to PM and I followed all the instructions until it says to install eSIM and that didn’t work. Then I tried to log in to the account on the app but it doesn’t work. The log in works only on the website. But I’m locked out because it’s asking for a sms verification code but my Fido is deactivated during this process and I have no SMS on PM so I’m kind of stuck now. Any suggestions?
10-07-2025 07:31 AM
@JunT Check phone setting sim manger the esim might have already installed and you just need to enable it it / make primary . If you have iPhone be sure to toggle on “turn on this line “ . And remove old providers sim and reboot the device or reset network setting and test again . If still no luck you can engage support to help fix just
