No network available
SallyC
Hello wonderful community.
Can you please help?
I switched my SIM card from my old iphone to a new iphone & cannot text or call.
My phone settings show ’no network available’
but the carrier shows PublicMobile.
how do I fix this?
thank you
1 ACCEPTED SOLUTION
Accepted Solutions
@SallyC
Check to see if your new phone is carrier locked. Go to Settings>General>About>Carrier Lock - if it is unlocked it will say No SIM restrictions.
If it is locked, you will need to check check contact the carrier listed.
hairbag1
Is new phone have a dual sim slot ? Try sim in different sim slot.
RossN
@SallyC is it a used phone? if it is try  your IMEI number at
devicecheck.ca. to see if it's blacklisted
@SallyC
@SallyC   better to leave your discussion on your other thread you started earlier
check if the phone is blacklisted
https://www.devicecheck.ca/check-status-device-canada/
SallyC
Thanks for the helpful suggestions, it is not blacklisted so will persue the avenue of if it is locked by PM. Thanks again
HI @SallyC
If  you put your PM SIM in the old phone , it works without problem?
You tried to put sim from another carrier to see if it works
Also, try to update the Carrier profile via Wifi or via iTune
