Friend referral
gbranscombe
Anyone have a code for the $10 off for friend referral. Thank you
gbranscombe
Just saw that thanks
tweakthis
I can see my code at the top right corner of the PM Overview log-in screen. I've used the code a few times to refer friends.
Good friendships deserve to be rewarded
Refer a friend and earn rewards for as long as they stay with us. Your friend will also receive a one-time $10 credit!
Tell your friends to use this code XXXX or "link" when they activate with Public Mobile.
gbranscombe
I got one . Thanks
RossN
@gbranscombe hello let me know if you still need one,I will send it to you 😀
gbranscombe
Thank you
MrSpock
@gbranscombe I will send you one in your community mailbox
