07-09-2022 04:46 PM
Yesterday it worked. Today, when trying to make or receive a call, I get the message "You have used up all your minutes....."
This is wrong because my usage report shows only 17 of 100 minutes used, and only a small amount of my data (about 20%) These figures are about right.
I have turned the phone on and off, with no change.
Simon is useless
Help, please
Service
07-12-2022 03:07 PM
@ganguy Good to hear your phone service has been restored, but yep, not great customer service if they couldn't be bothered to keep you updated as to what was happening.
07-12-2022 02:59 PM
Resolution!
I got switched through 3 CSA's, none of whom passed on the info to the next, all saying that they were following the trouble ticket at tech support. I have no idea why they can't communicate with them directly. Without being advised, my phone started working normally. I have no idea who or what made it happen.What a PIA! Anyway, consider this thread closed.
Thanks to everyone who chipped in on this issue.
Ganguy
07-11-2022 09:39 PM
Day 3 still no response or resolution from tech department. Still no phone. Looks like I'm out of luck, maybe a different supplier is the answer.
07-10-2022 12:42 PM
Yesterday I was able to get on the chatline. We spent about an hour during which the agent tried everything within his/her capability. Nothing worked. They even reset my usage to zero. Still the "no minutes" message. Then the chat-er initiated a trouble ticket with the tech department. (I thought I was dealing with them online.) Guess what, they are going to contact me by phone!. Still nothing heard from them, and, no service. This is all pretty shabby.
07-09-2022 05:34 PM
Good idea. That was my next suggestion. Submit ticket for CSA help.
07-09-2022
05:31 PM
07-19-2022
09:35 AM
Luddite
Thanks
Network reset did not work.
I'm going to try submitting a trouble ticket
(✅. ..... Luddite)
07-09-2022 05:27 PM
Thanks for confirming.
A few other things to try:
Network reset of phone
Remove SIm card and put in another working phone. See whether your call works. Then re-insert to your original phone.
07-09-2022 05:17 PM
Yes, and as I said before it shows minimal usage! In minutes, 17 of 100 used.
07-09-2022 05:15 PM
Do you see the 100 minute counter in My Data and Add on section?
See below
If you don't see the counter, that means according to PM, you used up your 100 minutes.
07-09-2022 05:01 PM
Restarting twice does not work (OFF/ON)
07-09-2022 04:57 PM
How do I reboot?
07-09-2022 04:54 PM
hi @ganguy it is a common glitch, please try reboot the phone. and try to enter 1 in front of the 10 digits num
07-09-2022 04:52 PM
As I said, usage report shows lots of time and data left. I scarcely use the phone.
07-09-2022 04:50 PM
07-09-2022 04:50 PM - edited 07-09-2022 04:52 PM
@ganguy hi the place you need to check is your data and add on section if you don't see a line there for minutes then they are al used up are you on the 50 or 100 outgoing minutes , there is a 500 min 5 dollare add on availiable if needed
