05-19-2022
08:08 PM
05-19-2022
09:29 PM
computergeek541
Bought a phone that was supposed to have a sim card and there are no instructions with the phone so i cant figure out how to open it and see if the sim card is in it or not.
05-20-2022 03:27 PM
Has customer support been in touch? Did you check your private message box at the top right corner of your screen for a little number to pop up indicating a reply from a CSA?
To contact customer support : Submit a support ticket via SIMon the chat bot Click here
Or if you cannot submit a ticket via SIMon then Click here ....for additional member supplied info.
05-20-2022 08:45 AM
How long does it usually take them to respond to that from yesterday?
05-19-2022 11:55 PM
Sorry to hear that, this has happened before to other CPO customers unfortunately. You can open that ticket (as suggested) with a CSA in the meantime you could either go in store to purchase a sim card or order from a place like Canadian Cell Supplies as its actually much cheaper and much quicker for delivery. You can then ask for a credit to your account for the sim you had to get on your own and maybe even a little more for your trouble
05-19-2022 10:14 PM
@Mrsfrink wrote:Yes, there was nothing in the box as the card and it won't let me submit a ticket.
HI @Mrsfrink to submit CPO related ticket, message CS agent here:
05-19-2022 09:35 PM
Your user manual...
https://www.manuals.ca/motorola/moto-g-pure/manual
05-19-2022 09:20 PM
Then send a private message. Use the second option below and skip my little rant in the linked post and just read the spoiler for more info before you send your message.
05-19-2022 09:13 PM
05-19-2022 09:10 PM
I realized that the problem was it was supposed to be sent with a sim card but it was not.
05-19-2022 09:08 PM
Moto g pure
05-19-2022 08:25 PM - edited 05-19-2022 08:25 PM
There is a small hole on the side of the phone. You will need the SIM tool or paper cIip and push the tool into the hole so the SIM tray will slide out.
What phone did you order so we can tell you the spot of the SIM tray?
05-19-2022 08:18 PM
HI @Mrsfrink Probably PM just missed the SIM, open ticket with PM CS Agent.
if you need one for activation, you can go to activate in a store, they will usually willing to give you a Free SIM card
The manual, many phone no longer ships with useful manual, download it online
05-19-2022 08:14 PM
What type of phone did you purchase? Youtube is very helpful if you need to learn about your new device.
05-19-2022 08:14 PM
The SIM card should be separate in the box with the tri-cut SIM in a credit card sized frame to pop out. It's likely the CPO department forgot to add your sim card to the shipping box. What kind of phone do you have?
You will have to contact customer support about the missing SIM card and either wait for a new one to arrive or ask for a credit and purchase one at a local retailer and submit the receipt.
