05-20-2022 03:03 PM
just paid my USA roaming charge, it is shown on my account as paid, the phone is still not not working, and says I used all funds available, and made payment while in USA, what's going on?
05-20-2022 04:12 PM
You can reach out to a CSA to explain your mistake and they can most likely likely put that 8 back in your available funds for your next renewal or add on
05-20-2022 04:08 PM
all working now, thanks
05-20-2022 04:06 PM
Ah. Was this purchase your first while away? Or have you been using add-ons before this purchase? And if so how long ago did you last buy talk? Have you since talked for more than a couple minutes on one call?
Maybe you could provide us an image of your plan details page.
05-20-2022 04:03 PM
no, but I couldn't find talk for $8 so had to buy talk and text for $15, now the phone is working, thanks
05-20-2022 04:03 PM
no, but couldn't find talk for $8 so bought text and talk for $15, now phone is working, thanks
05-20-2022 04:01 PM
05-20-2022 03:59 PM
@AndrewOstrowski As indicated by @dust2dust , your add on is for texting (SMS/MMS) only. was that your intention?
05-20-2022 03:36 PM
phone selected T mobile, trying AT &T, says I used all minutes
05-20-2022 03:32 PM
That's texting.
05-20-2022 03:31 PM
Date Transaction Type Credit (Payments) Debit (Charges) Balance
| May 20, 2022 | US Roaming - Unltd. Txt/Itinérance É-U - Textos illimités | $8.00 | $17.00 |
05-20-2022 03:27 PM
no text message, T-Mobile on, roaming on, it's not working, the message says no funds? an I just paid and account shows the USA roaming $8 for talk???
05-20-2022 03:26 PM
HI @AndrewOstrowski You tried AT&T as well?
05-20-2022 03:26 PM
yes I did just that, and my account shows USA add on for $8 text is on my account, still not working, T-mobile on and roaming on
05-20-2022 03:24 PM
05-20-2022 03:11 PM
HI @AndrewOstrowski does the add-on show up on your Plan details page? Remember to buy add-on, it is a 2 steps process. Load the fund first and then you have to go back and buy
If you did both parts, make sure you you manually select T-Mobile or AT&T. Also, if you need data, make sure Roaming Data is enabled
05-20-2022 03:05 PM
Did you get the welcome to the US text message? If not then you want to scan and connect to T-Mobile. If you bought data then turn on data roaming.
