02-23-2023
05:06 PM
02-23-2023
06:42 PM
computergeek541
02-23-2023 06:39 PM
Thank you!!
That worked
02-23-2023 05:45 PM
@DeanColes1 wrote:My data limit is not set, i think it might gave something to do with apn settings
@DeanColes1 compare yours with this and make update if needed
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include dun for hotspot)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
02-23-2023 05:41 PM
Data was working 10 days ago and i only used 159 mb total
02-23-2023 05:40 PM
02-23-2023 05:30 PM
Im only at 159 mb used at that was 10 days ago. I reset my phone and still no data
02-23-2023 05:28 PM - edited 02-23-2023 05:30 PM
@DeanColes1 so data was working before and just stopped working? Check if you have data limit enabled, I'd so, disable it. You might have a page similar to this:
02-23-2023 05:24 PM
My data is turned on and i hacent reached my limit
02-23-2023 05:13 PM
Have you signed into your self-serve account to see why?
You're probably out of data or there is a service outage or you have a data limiter set on your device.
Let us know what you've done to figure it out and we can help with other options.
02-23-2023 05:08 PM
@DeanColes1 Make sure data enabled on your phone and no data limit set also , maybe check that you have data left
Try again incognito mode/private mode or a different device or lap top or simply try refreshing the page when logged in
