12-12-2019 10:52 PM - edited 01-05-2022 08:31 AM
I've just switched to Public Mobile and I am not able to use data. PM documentation suggests to change APN settings but I can't get to them on my phone (not to the ones they show in the how-to articles). The ones I see don't have options that are needed. I've found several threads discussing this issue but no real resolution.
02-01-2020 07:21 PM - edited 02-01-2020 07:23 PM
Hi,
Issue is easily solved by downloading the APN setting from https://www.unlockit.co.nz/
for you specific network
12-16-2019 10:31 AM
There ARE settings on an iPhone for updating your APN settings.
2A) You might NOT be able to change or update or even see the next two.If not, nothing to worry about!
12-16-2019 10:27 AM - edited 12-16-2019 10:29 AM
12-16-2019 10:19 AM
Talk to the mods
12-16-2019 09:24 AM
@Kidsmom wrote:I've just switched to Public Mobile and I am not able to use data. PM documentation suggests to change APN settings but I can't get to them on my phone (not to the ones they show in the how-to articles). The ones I see don't have options that are needed. I've found several threads discussing this issue but no real resolution.
12-16-2019 06:25 AM
@Kidsmom Go into your settings and see if there are any updates available. Make sure you have access to WiFi in order to do so...perhaps @iPhoneUser is available to advise you as many of us are Android users. I will look to see the minimum update that is necessary for your iPhone to access mobile data.
12-13-2019 07:10 PM
@Kidsmom If none of the suggestions are working for you, you should submit a ticket to moderators via SIMon here: https://publicmobile.ca.ada.support/chat/
Type in 'rep', select 'contact us', select 'submit ticket' and follow the prompts to finish submitting your ticket.
There is alway a nominal amount of buffer data used (approx. 5.3mb) whenever data is switched on. This can be reset by turning the data/airplane mode on and off. If it's more that amount being used, check to see if one of your apps is an issue. If you haven't already, then restrict background data on your phone settings.
12-13-2019 07:02 PM
Thank you for all the suggestions, nothing seems to work ...
Phone is unlocked. I still have almost 1GB data left (for some reason, it shows that 10 MB have been used, not sure how). I've subscribed yesterday so the data never worked.
I've been resetting multiple times and in multiple ways.
Found this and tried (but didn't help):
What you can do take sim off reset network setting turn off phone insert sim and restart its usually set all network setting automatically
Try this hopefully will help you
12-12-2019 11:20 PM
@KidsmomThere is no option to enter APN settings in iOS. Try Settings -> General -> Reset Network Settings and see if it resets it.
12-12-2019 11:16 PM - edited 12-12-2019 11:22 PM
So which plan did you subscribe to ? If it was the $15 plan, you need a valid credit card and enable Autopay to get the 250mb of data.
Log into My Account / Data and Add-ons to review your dt alottment for your plan.
Let us know what you see under data.If you don't see any, that means you've either already used it up (250mb isn't a lot of data)...or you don't have any data.
Be aware that PM is giving everyone a gift of a FREE 1GB of data add-on and 400 minutes of International calling add-on. There's no catch...it's free.
Make sure that Data is enabled as well...turn On Roaming. Restart phone.
12-12-2019 10:57 PM
Sure your phone is unlocked?
