10-29-2021 12:58 AM - edited 01-06-2022 03:54 AM
Hello,
When my iPhone 6 is on wi-fi and I'm playing video clips on Instagram, etc. the audio is fine.
When the phone is on data (not connected to wi-fi) there is no audio.
Anybody has any idea why is that?
Best regards,
11-04-2021 08:05 PM
11-04-2021 07:55 PM
Hi,
No audio usually happened in the car while waiting or riding a ferry boat, for example.
My phone is always connected to the car's entertainment system via the Bluetooth.
I have to turn the Bluetooth off now in order to play video clips with audio.
11-04-2021 02:20 PM - edited 11-04-2021 02:21 PM
lol. I have always had iPhones but never see an opportunity to see a BlueTooth device to connect to. But my neighbours Range and some other weird thing shows as a Wifi connection.
11-04-2021 11:35 AM
That's essentially my question as well. It's a strange problem, unless something was connected. So many devices are Bluetooth-enabled these days, and our devices tend to auto-connect for convenience, but sometimes this has unexpected consequences. Or, this may just be a "bug" in the iPhone since others seem to have the issue too.
This is one great thing about these forums - seeing what's out there and learning about new and different technologies/quirks/etc. 🙂
11-04-2021 11:30 AM
@BlueB Would you not see what you were connected to, if you were, when Bluetooth is turned-on. This could be interesting.....like a device next door or?
11-04-2021 11:08 AM
That's great to hear that turning Bluetooth off worked. Do you know if there was something connected via Bluetooth? That could explain why audio was going "there" as opposed to your phone. If not, it's strange, but still glad it worked. 🙂
10-29-2021 04:00 PM
Turning Bluetooth off did the trick. Audio is back when the phone is on data. Will continue testing it, though.
10-29-2021 03:58 PM
I followed esjliv suggestion and turn off Bluetooth on the phone. This did the trick. Audio is back while the phone is data (LTE)
10-29-2021 03:51 PM
Turning off Bluetooth on my iPhone 6 did the trick. Audio is back in video clips (Instagram, etc.)
while the phone is on data (LTE) I will continue testing the phone in different situations.
Thank you very much. Great suggestion!
10-29-2021 01:47 PM
Yikes......bad solution.
10-29-2021 01:40 PM - edited 10-29-2021 01:56 PM
10-29-2021 01:13 PM
You might want to google the problem as it looks like your model has audio issues.
10-29-2021 01:05 PM
@softech wrote:Worst case, bring it to Apple Store for assistance
I would not say 'worst case' but maybe the optimal solution. Instead of trying this and that (and maybe causing something even worse) if Apple store is accessible just go there and let them fix it for you AND explain to you why is this happening.
Then let us know what resolved your issue so everybody knows how to handle such issue.
10-29-2021 12:35 PM
@arkshn I am pretty sure it's not an issue with the PM service. (but you can try to put your PM sim in another phone to confirm)
Did you try to put another SIM into your phone and see if it has the same issue or not?
10-29-2021 12:28 PM
That's weird, especially since you're downloading that data anyways. I'm curious what solution will fix your problem - let us know!
On a similar note, you do NOT need to reseat your SIM card. If the rest of your phone services work, then your phone is able to access the SIM fine to log on to the Public Mobile network.
10-29-2021 12:10 PM - edited 10-29-2021 12:11 PM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit Here link,
click Here link,
Ensure you have the correct APN settings by visit Here link,
and do Rebooting your phone,
*what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
and can you try manually selecting network "3G ONLY" or WCDMA only,
for iPhone visit Here link
or Here link
This is quick and simple,
10-29-2021 06:09 AM
@arkshn wrote:Hello,
Best regards,
@arkshn try this troubleshooting :
10-29-2021 06:05 AM
interesting.. i search around and there were couple posts online that have the same issue with iPhone 6. However, there were no definite solution with the issue. Start with phone reboot, also make sure your phone is updated. Worst case, bring it to Apple Store for assistance
10-29-2021 02:15 AM
Best regards,
Try cycling phone off / on again. It's a long-shot...but might work.
Let us know one way or the other.
