07-25-2022
01:25 PM
07-26-2022
02:00 AM
computergeek541
I need some help please. Don’t remember my email that I signed up with and does not exist anymore.
07-25-2022 01:35 PM
HI @Bubz You can open ticket with CS Agent and have them to lookup the email address you used and reset the password for you as well
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
First type: "Forgot log in information"
Then Click "Contact Us"
Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
07-25-2022 01:27 PM - edited 07-25-2022 01:27 PM
You can try this:
At My Account's Forgot Password, https://myaccount.publicmobile.ca/en/forgot-password
put any email address you could have used and see which one work and get you to step 2
If none of them work, open ticket with PM Support
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
