11-03-2016 08:41 PM - edited 01-04-2022 04:15 PM
The other day I changed my plan to take advantage of the new 4gigs per month offer. I am set to autopay, my plan renews on the 5th of this month. After this change I lost service for some reason. Can someone help. Just says no service cannot find public mobile? Thank you.
11-05-2016 02:30 PM
It happened to me too. And autopay stopped by itself. I had to log in to my account to set up again.
11-05-2016 02:21 PM
Dam looks like my phone is busted! would not work in other phone due to phone being locked. Thanks guys for the support.
11-04-2016 01:19 PM
Hey @nastypc
Your account in the back-end appears to be active and functional.
Did you change phone, drop it, remove the SIM, etc ? Please try turning it off, removing the SIM for a minute then reinserting it and power back on.
Please let us know if your service is still not functional, we'll further investigate.
Mary
11-04-2016 08:26 AM
11-04-2016 08:08 AM
Still no service. Hope we can fix this soon thanks for suggestions.
11-04-2016 07:28 AM
This happened to me when I joined - literally just had to re-insert my sim and it was fine
11-03-2016 09:14 PM
While you are waiting try removing the SIM for a few minutes, install and reboot.
Meanwhile, while service is down you can make phone calls with an application like that from fongo.com. It provides free calling across Canada from wherever you are connected to wifi.
Hang in there.
11-03-2016 08:59 PM
You can private message a Public Mobile moderator to have a look at your account. To private message the moderator, click on the moderator's name that I have tagged below, and on the right hand side of the page, click "send this user a private message". Hopefully your calling issue gets resolved soon!
