02-11-2021 08:39 PM - edited 01-05-2022 05:14 PM
Activated new sim card, no errors, credit card has been charged. Insert sim card into phone - it never connects to the network, I just get "No Service". Any ideas? I have opened a ticket and will apparently hear back in 48 hours - wow! Phone is an unlocked iPhone SE (2016).
Joining Public
02-12-2021 10:01 AM - edited 02-12-2021 10:02 AM
@triswright wrote:magically started working 14 hours after activation. still waiting for response to ticket. Now another 24-48 hours to transfer my number!
@triswright Make sure you keep using your old sim/service. You will need it to receive a SMS from your old provider to authorize the port.
Here is a link to a Public Mobile page on porting that may be useful:
https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
02-12-2021
09:51 AM
02-21-2021
01:48 PM
Luddite
[Ouch; 14 hours to activate .......... Luddite]
02-12-2021 12:41 AM
@triswright wrote:Yes I did and it couldn’t connect either so I’m guessing it’s the SIM card itself or something on their network side. Switching from Koodo and no issues there so I don’t think it’s the phones .
It may take up to 48 hours from the time you submitted a ticket to the moderators for a reply. Keep an eye on the envelope icon in the top right hand corner for a reply from the moderators.
02-12-2021 12:35 AM
02-12-2021 12:31 AM
@triswright wrote:thanks for the suggestions, have tried them all except the iTunes one. I don’t have iTunes on a computer anywhere any more. Anyway, same issue, so far it’s been 6 hours, I will have to wait for public mobile support to figure it out...
Did you try the sim in another unlocked phone?
02-12-2021 12:29 AM
02-12-2021 12:18 AM
@triswright wrote:Activated new sim card, no errors, credit card has been charged. Insert sim card into phone - it never connects to the network, I just get "No Service". Any ideas? I have opened a ticket and will apparently hear back in 48 hours - wow! Is this for real? Phone is an unlocked iPhone SE (2016).
I would try this:
Connect your phone to a computer using a USB cable. Run iTunes. This will connect to the Apple activation server. When inserting a new SIM card or putting one in that is from a different carrier that is already being used sometimes requires the phone to check with Apple as to if the phone is unlocked/if that carrier's SIM card is allowed to be used in the device. While iPhones with the newest operating system can connect to the Apple activation services without the use of a seperate computer system, this option can be more reliable as it does require the configuation of internet usage on the device itself before this can be done.
02-11-2021 09:52 PM
how long you have waited? Although it usually quick, like with 15 mins, but it could take as long as 4 hours sometimes.
In the mean time, keep reboot your system every 15 mins and see
02-11-2021 09:36 PM
@triswright try power off your phone then reboot the phone. My friend had the same problem and all it needed was all it was.
02-11-2021 08:45 PM - edited 02-11-2021 08:49 PM
In all likelihood, this will resolve in an hour or two.
You could try this step-by-step troubleshooter: (pay particular attention to #4)
- Make sure airplane mode is off
- Power OFF your device, wait 1 minute, turn on and check for signal bars
- Check on account self-serve that your account status is Active
- While on self-serve, check that SIM card number under “Change Sim card” matches the SIM card number in your phone
- Make sure the device is not locked to a different carrier.
- Make sure you’re in a covered area and there are no cellular outages
- Change wifi calling preferences to Cellular Preferred or Cellular Only
- Set network mode to Auto
- Reset network settings
- Update device software to latest version
- Perform a manual network selection
02-11-2021 08:41 PM - edited 02-11-2021 08:44 PM
Can you ensure the SIM card is seated correctly and not loose.Can you try your sim in another unlocked phone? This will help to know whether it is a phone vs account issue.
