@ No phone service
pjpj1
Suddenly, mid-day this past week, could no longer receive or make calls. After dialing, there is a long pause of silence, then a Bing! And sometimes the message "No Mobile network available for calls" appears. I've waited this out for several days in case of a storm-related (or other) outage. But am frustrated and seeking guidance. Have sent in a service ticket, and want to cover all bases. Thanks in advance if you've wisdom to share ...
1 REPLY 1
@pjpj1
mobile data works?  Text works?
What model of phone is that?  Try Rebooting your phone and click Reset Network Settings
If that still fails, it could be a problem with the lack of VoLTE service on your model of phone.   If your phone is not on PM's VoLTE whitelist , then it will be using 3G for voice and it might be affected by this:
Telus is currently  refarming the 850MHz band 5 spectrum and hence you are left with 1900MHz for voice calls.
https://www.publicmobile.ca/en/get-help/articles/850-turndown
While one compatible band is still sufficient, reality is  1900 MHz could have less coverage, depending on your proximity to a tower and hence you are seeing a poor or no coverage with voice  (Data is not impacted as your phone has the compatible bands on 4G/5G)
You can confirm if your phone is on the VoLTE by using the IMEI checker on this page:
 https://www.publicmobile.ca/en/on/get-help/articles/volte
If this is really what affecting your voice calls, there is really nothing much you can do other than getting a phone that is on PM's own VoLTE whitelist.
