02-22-2022 03:42 PM
I am getting data right now. Started this morning. Checked my account and can confirm i have Data left. I do not get the data icon on my phone and saying " No Internet Connection". Anyone else having the same problem? I am able to make and receive calls though.
02-22-2022 04:40 PM
If you are getting data now and you have accessed data in the past with the same settings then there is no need to change anything.
If could just be a network outage in your area.
02-22-2022 04:39 PM - edited 02-22-2022 04:42 PM
@mmaclan1 - is your Data option turned ON ?
What is your model of phone? If iphone with IOS beta see here, maybe this affects you: https://productioncommunity.publicmobile.ca/t5/Get-Support/Fix-for-iOS-15-4-19E5209h-Data-issue-Reso...
EDIT: sorry, you are all fixed up - good to hear!
02-22-2022
04:14 PM
03-04-2022
04:31 PM
Luddite
Hi yes i came across this article and followed the instructions, no luck. I actually ended up doing a full network reset which resets, mobile data settings also, and fixed my problem.
[Self-help succeeds ....... Luddite]
02-22-2022 03:52 PM
Have you checked your APN settings?
