No Calling
JLH5
I can text but I cannot call out or receive calls.
2 beeps and it hangs
9 REPLIES 9
Milk
If you have an iPhone do a complete update and that should solve the problem - of course make sure to store your settings and emails on your iCloud account.
will13am
This problem sounds like the remnants of the calling bug that was around not too long ago.
Meow
To Contact CSA-agent there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Having a ticket is preferred way to contact agent as they might respond faster then receiving personal mail.
If opening a ticket does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+) Here
Agent’s response is usually between 15 and 120 minutes with a ticket. Private messaging might take longer.
Watch for envelope in top right corner of Community page. It will show Number of unread emails.
HI @JLH5
is the text just iMessage? if it is, you got it from Wifi , not from PM networks
Try to reboot the phone first
or try the sim card on another phone if you can get a temporary phone to test
If all those do not help, please open ticket with PM support at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
@JLH5 wrote:
I did both
How do I contact a Moderator?
Or agent?
@JLH5
­­­Public Mobile Representatives customer support­­­ agents (CSA) can be contacted by either two methods, found here:
but what other details can you provide?
EDIT, just noticed @softech provided methods to contact CSA as well above.
@JLH5 - what troubleshooting have you tried, please provide details like is this a new or existing account. Did your account just renew? Etc.
Do one or more of the below may help with that message or finicky things:
  • restart your phone
  • toggle into and out of airplane mode
  • perform a Reset of the device's Network Settings
JLH5
I did both
Or agent?
@JLH5   are you newly join ?   If you are, do you see the phone showing connected to PM network?  If it shows No network, or no status bar, likely it is a sim card provisioning issue.  It is an easy fix for PM, just need to open ticket with them via chatbot
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
@JLH5  Try to reboot phone , or even network settings see if this helps
