New sign up
wjosh8857
It's been over 3 days. Still haven't heard back about my issues.
9 REPLIES 9
wjosh8857
How can I get in contact with the porting team?
Frank52
@wjosh8857 wrote:
Having issues porting my no# from Rogers to Public mobile.  Rogers say, My account is still active on their end. I can call and text out. But can't receive anything
@wjosh8857 I had a similar situation when I tried porting over from Chatr but was able to get it resolved when I called the porting team! I suggest contacting the number of the porting team. They should be able to help you 🙂
@wjosh8857 wrote:
Rogers say my account  with them is still active. After I followed all the prompts when signing up on Dec 30th.
HI @wjosh8857
You can call Public Mobile porting team to provide the correct Info and get status update.  I will send you the porting team number.  Please check your Community inbox for my message
You'll have to contact Public using the ticketing system/private message system as mentioend earlier.  The symptoms you've given mean that your number hasn't been transferred over (yet).
wjosh8857
wjosh8857
Chalupa_Batman
Hey @wjosh8857
What issues were you having? Maybe we can help??
@wjosh8857  So you already submitted a ticket to support ?? If so check your in box for reply . Or use this link to the inbox for reply
of no reply please submit another ticket using this direct link to support
send  a  private message   To CS_Agents
Sansan
Where did you contact? Did you check your inbox in the Community?
Send another message here.
