New plan $34 for old customers with loyalty dollars.
SP12
If I switch to new plan just offered to us will my loyalty, auto pay & friends dollars I have accumulated be applied.? It says in $34 us/cda plan that $1.70 points per month.?
Chalupa_Batman
Hi @SP12
You have nothing to worry about. You will continue to keep your Legacy Rewards. I've switched plans 5 times in 5 years and you still keep them. I too just switched to this plan.
DennyCrane
You'll keep all your legacy rewards discounts, but you won't also get the $1.70 in points noted in the plan description. It's one or the other, and yours is better.
OlivierR
Yes you will keep your loyalty rewards even when changing plans!
